F2 carb sync
The airbox can be on or off. I think it is WAY easier with it off.
As long as you are getting an accurate idle (~1700 rpms) the airbox won't have a detrimental effect on the amount of vacuum being pulled through each cylinder. Just remember, cylinder number 2 is your base reading. Balance 1,3, and 4 around cylinder 2's readings. Good luck.
