Eliminating Speedometer gear in front wheel
Old Apr 29, 2017 | 10:58 AM
ohiophotog's Avatar
Default Eliminating Speedometer gear in front wheel
Hello all,
I replaced my stock guages with a Koso unit which came with its own magnetic speedo setup. I still have my speedo gear mounted to the front wheel and it is making all kinds of noise. What I wanted to do is eliminate it and run the axle/bearing/spacer setup from the F3. Does anyone know if this can be done or has done it?
Old May 4, 2017 | 01:25 PM
ohiophotog's Avatar
Fixed my issue, pulled the plastic gear out of the housing and put it back together, no noise. F3 spacer and dust seal would have worked although there would have been nothing to seal the F2's dust seal against the wheel.
nthrx
F2 Tech
Jun 3, 2013 04:20 PM
Sand.Man
Apr 4, 2008 02:59 PM
bmg velocity
Dec 27, 2007 05:05 PM
cleansho93
Sep 26, 2007 03:49 PM
terror
Sep 3, 2007 01:50 PM
