Do I need to rejet?
Old May 20, 2014 | 09:30 AM
f2_fighter's Avatar
Default Do I need to rejet?
Hello,
I chopped my exhaust can and for a better look, and I need to know if I will need to buy a jet kit. Everything else is stock besides the exhaust mod, which is actually a yamaha exhaust the previous owner put on. Seems to be running leaner than normal.
Thanks.
Old May 20, 2014 | 03:49 PM
azacbr6's Avatar
I have the same problem at the moment, I added a race can and K&N filter and now the bike hesitate a bit on acceleration and feels like it wants to stall sometimes, The best thing is to have it checked first (put it on dyno), it might only need fuel/air mixture adjusting, otherwise it might need a jet kit.
Old May 21, 2014 | 06:53 AM
f2_fighter's Avatar
I know adjusting the fuel/air screw will change lower rpm response. Is there a trick to adjusting the screw because it is a bitch to get to. I bought one of these with the D Shape attachment to get to mine but is still a pain.
Old May 21, 2014 | 09:47 AM
Conrice's Avatar
You shouldn't need a re-jet from cutting a can down.
You can also use a flat-head 1/4 inch drive attachment to adjust them on the bike by itself. If you do do it, I wouldn't go more than 1/4 turn more open.
Old May 22, 2014 | 07:22 AM
f2_fighter's Avatar
Ok thanks. I will have to give that a try.
wonkiwheel
F2 Tech
Mar 10, 2014 11:15 AM
Edward Tristram
Jul 13, 2012 04:10 AM
JMoore84
Nov 23, 2009 10:11 PM
Eviltapper
Apr 7, 2006 01:26 PM
ekathryn86
Aug 2, 2005 07:17 PM
