Coolant and oil drain plug??
Old Mar 17, 2010 | 07:37 PM
live4liftin's Avatar
Default Coolant and oil drain plug??
I am changing both of these fluid 2morrow and I was wondering just where exactly the coolant drain plug and oil drain plug is on a 94 F2. My nack on the coolant is on the left side under a black cap pointing down inbetween the two hoses, it has a copper washer on it and is ponting down. Am I right or way off. Please help!?
Old Mar 17, 2010 | 08:09 PM
CrashTECH's Avatar
Oil drain plug... make damn sure you inspect the plug well before putting it back... I think mine is good and hosed up. Can't ride because the girl has no blood!
https://cbrforum.com/forum/cbr-600f2-16/600-f2-oil-drain-plug-93878/
Old Mar 17, 2010 | 08:37 PM
Ok I got the oil plug part down now. And for the coolant I see a small circle type thing with the radiator hose running to it with 4 bolts around it and one odd ball in a staggered position making it 5 bolts total. Is this the drain plug? Its a rusted color while the other 4 are not.
Old Mar 17, 2010 | 08:48 PM
Sand.Man's Avatar
The coolant drain plug is located on the water pump.
There should be one bolt with a copper washer, that one is the drain.
Old Mar 17, 2010 | 09:04 PM
Where exactly and what does this water pump look like?
Old Mar 17, 2010 | 09:26 PM
Kuroshio's Avatar
http://fiche.ronayers.com/Index.cfm/...oup/WATER_PUMP
Really can't miss it. Water pump has the giant radiator hose going onto it.
Old Mar 18, 2010 | 08:33 AM
dustinjklee's Avatar
the water pump is located just beneath the front sprocket on the left side. the drain plug to drain your coolant will be the inner most bolt on the water pump. its almost directly in the center of the pump. just a tiny bit low and to the left. its going to be the rusted one pretty much lol. and when your draining the coolant take your radiator cap off or it will draining really slow. ......... if you look on that diagram its bolt number 12..........
Old Mar 18, 2010 | 10:01 AM
halffast1g's Avatar
just take off the lower radiator hose COUGH
Old Mar 19, 2010 | 01:22 PM
CBRfenatic93's Avatar
+1 for just taking off the lower radiator hose. But where something you dont mind getting a little coolant on cause the **** drains about 100X faster. lol
dachamp312
Mar 15, 2011 11:32 AM
94_F2_KING
Aug 23, 2009 12:19 PM
t3gr4
May 20, 2009 07:28 PM
dwarfdwarf
Jun 11, 2008 10:52 PM
tinter
Jun 28, 2005 01:11 AM
