Clutch help.
Old Sep 3, 2014 | 06:09 PM
underground-mpyre's Avatar
Default Clutch help.
I just swapped out my clutches and immediately having this problem and can't figure it out.
Ok, starts in neutral, but when I shift to 1st or 2nd with the clutch held in, the bike jumps forward and dies. I can put it back to neutral and starts right up, but when i shift to any gear the bike leaps forward and dies with the clutch in. Thoughts???
Old Sep 3, 2014 | 07:07 PM
Conrice's Avatar
The clutch isn't disengaging - the plates aren't separating. Go back through and check everything, specifically the judder springs and the first couple of plates.
(Ask me how I know.) I had the same exact thing happen on the 600rr that I owned.
Old Sep 4, 2014 | 05:12 AM
I thought I put it all back together perfectly. I don't know what I did wrong for it to be so tight. I will check again.
Would I maybe back out the clutch lifter bolts out a little to take the tension off or what if I don't find anything?
Old Sep 8, 2014 | 07:59 AM
Took all the plates out and soaked them in oil and reassembled them carefully and adjusted the cables. Took me all afternoon with no avail. Scratching my head at this point.
Zandaloo
Aug 22, 2013 03:26 PM
Bordo
Sep 21, 2012 07:33 PM
02f4irider
Mar 6, 2009 07:50 PM
red stinger
Jul 19, 2008 12:17 AM
cyber00677
Jun 23, 2007 06:17 PM
