Clicking sound from front of engine?
Old Nov 28, 2010 | 07:53 PM
jeffcp1's Avatar
Default Clicking sound from front of engine?
Hello guys do not write often but this has got me stumped? When my f2 is at idle there will be a clicking sound and the rpms drop a few hundred then they go back up? It sounds like a valve actuating but cant find anything? Thought it was the fan coming on and off but its even at low temps? any suggestions would be great, just annoying
Old Nov 28, 2010 | 08:21 PM
Sprock's Avatar
Could be downpipes more specifically a leaky or blown exhaust gasket making that ticking/clicking noise !
maybe even a small pinhole in the pipes themselves if they are corroded !
Old Dec 2, 2010 | 08:44 AM
squale147's Avatar
July 2013 ROTM
cct.. it sounds like that might be it..
Old Dec 2, 2010 | 08:58 AM
kazspeed's Avatar
Not sure if this would be the CCT, I know my CCTL needs to be replaced but it only makes a sound when i hit 4.5-5k rpms. I see/hear no noticeable difference when in idle.
Old Dec 3, 2010 | 10:15 PM
jeffcp1's Avatar
thanks for the info but its not it, when at idle and not all of the time there will be a click and then the idle drops 200-300 rpms then goes back up? like it wants to stall but it corrects it self, the rpm drop is so slight but its really annoying.
Old Dec 4, 2010 | 12:19 AM
Sand.Man's Avatar
One single click and then the RPM drops? Sounds like an electrical relay clicking on and putting too much load on the stator or somethin.
That's a noodle scratcher.
Old Dec 6, 2010 | 03:23 PM
JesseAwesome's Avatar
Flux capacitor is out of adjustment. Happens on these older model bikes. 4-5k in sixth gear is roughly 88mph, so that's about the right speed to start seeing the flux capacitor to act up. Not quite sure why it only happens at 88mph, but Doc Browns Flux Capacitor theorum would explain it... if you can stand a crazy read.
Old Dec 6, 2010 | 10:08 PM
Sprock's Avatar
Looks like Jesse's been watching too many back to the future reruns
Old Dec 16, 2010 | 11:12 AM
squale147's Avatar
July 2013 ROTM
that could be it...if the battery is weak and then the fan comes on it will put more of a load on the charging system.. the clicking could be the fan relay turning on and off ....but just a guess,,
Ls1Mx5
F2 Tech
Apr 10, 2013 11:35 PM
T_roy
Dec 2, 2008 02:57 PM
BLACKEDOUTf4
Jun 26, 2008 01:14 PM
c0ldf1ame
Sep 9, 2007 01:58 PM
brancart1
Oct 21, 2005 03:08 PM
