cam chain tension release issue
Old Apr 16, 2014 | 08:32 PM
600f2matt's Avatar
Default cam chain tension release issue
So i used this guide to look into shimming valves and it all seems great, no problems... except for one...
https://cbrforum.com/forum/stickies-9...-guide-101969/
Where it talks about unscrewing the bolt in the back of the CCT and then using a screwdriver to i THINK release the tension on the cam chain to get the cams out, Well i dont have that bolt. my CCT bolts onto the motor with the 2 bolts and thats it the rest is smooth. So before i make a wrong move i am guessing i would just completely remove the tensioner to do this job?
thanks in advance to anyone that can help me out. I really need it.
ALSO, i am looking to do this based on a engine rattle i get only on hot starts after fueling up or running into the store kind of stuff, which doesnt sound like your typical worn out CCT and besides valves i cant imagine what it might be.
Old Apr 16, 2014 | 10:23 PM
Mattson's Avatar
Link's bad.... but yes the original cct only has the two bolts that fix it into the engine, I'd assume in the sample engine there must be a manual APE style cct. Just lift it out after unscrewing.
Arthur48
Oct 24, 2016 06:59 AM
xankriz
Jun 16, 2010 07:53 AM
tombooze
Mar 10, 2007 01:24 PM
TweakedCBR929RR
Apr 14, 2006 02:39 AM
koelzer18
Mar 19, 2006 08:12 PM
