Blown ECU?
Old Mar 27, 2013 | 12:11 PM
ko67's Avatar
Default Blown ECU?
My r/r fried and fried took the wiring harness with it. I replaced the r/r and the wiring harness.
Now the bike is running real rough. It will idle with the choke wide open, but won't go above 1K. If I close the choke or give it gas it will die instantly.
Ran perfectly before the death of my r/r.
Could it have fried the ECU? How do I check it.
I have a line on a used one locally so I want to jump on it.
Old Mar 27, 2013 | 02:49 PM
JNSRacing's Avatar
Welcome Crew and ROTY 2014
There's no ECU on the F2, as it's carbureted, and not fuel injected, so I'm guessing you're maybe talking about the Ignition Control Module (ICM)?
If so, there are tests in section 16 of the service manual, for both the coils and the ICM.
I know these new issues seem to correspond with the R/R toasting on you, and it may indeed be related, but based on your description of how the choke circuit plays into this, is sounds more like a fuel delivery issue.
Also, have you checked your plugs, to see if they're fouled out, and have you checked each of them for good spark?
Anyway, good luck getting it sorted out!
Old Mar 27, 2013 | 05:13 PM
ko67's Avatar
Yeah that thing. Haha.
Pulling the plugs was on the to do list. It is backfiring a little too.
Thanks!
Roger cbr
Jan 20, 2014 01:58 PM
Memphistn3000
Jun 9, 2009 03:11 PM
hawkwind
The Hurricane Saloon
May 12, 2009 06:46 AM
bobjoezx
Mar 24, 2008 02:06 PM
