Brakes info
Old Apr 3, 2013 | 12:24 PM
jdub22's Avatar
Default Brakes info
Can someone give me some pointers or tips that will help me tackle changing all of the brake pads. I mean are there any tricks of the trade? It should be relatively easy compared to cleaning the carbs right? Any help will be appreciated.
Old Apr 3, 2013 | 01:34 PM
CorruptFile's Avatar
June 2013 ROTM
Your probably best off to remove the calipers all together and give them a go through. When you fit new pads, they will be thicker and not fit over the rotors so you will need to compress them (I used a vice). Lube the caliper slide pins and use never seize on the pad pins.
Bleed all the old brake fluid out and use some fresh stuff. Be prepared to be bleeding those fronts for a long time
Old Apr 4, 2013 | 05:47 AM
gtcole's Avatar
Welcome Crew
If you decide to "flush" the front calipers by draining the old fluid, when you refil it, gravity bleed it first. It will make bleeding a little bit easier. To do that just top off the master cylinder, leave the cover off, and open the bleeder screws on the caliper. once you have a flow of fluid, shut the bleeders and proceed to bleed....... may still take you awhile but it gets alot of air out.
If you can, may be worth it to change the seals in the calipers too. Think they are like 20 bucks a set. But you can make sure your pistons move freely, don't leak, and dont stick.
Old Apr 4, 2013 | 06:24 PM
jdub22's Avatar
How exactly do I bleed them?
Old Apr 4, 2013 | 08:34 PM
June 2013 ROTM
Haha but in all seriousness, the FSM tells you how to do it. Not hard at all, just a bit time consuming.
Old Apr 5, 2013 | 11:30 PM
jdub22's Avatar
Ya well I'm to cheap to buy a manual. I just want some tips. I have bleed car brakes before so I imagine its the same.
Old Apr 5, 2013 | 11:39 PM
June 2013 ROTM
Save you a few duckets
Motorcycle Honda CBR600F2 Repair Manual Download
Old Apr 6, 2013 | 08:41 AM
RedBaron's Avatar
If your just want to change the pads, leave the caliper connected, use a g-clamp and one of the old pads to push the piston back and slot your new ones in.
Pad changes are quick and easy compared to carbs.
Nytmr
Dec 21, 2013 09:16 PM
MaxTO
May 16, 2012 07:01 PM
tomttt
How To's
Jan 22, 2010 08:36 PM
studdermonkey
Aug 27, 2007 07:48 AM
