bike fell over....no oil pressure....
Old Apr 16, 2010 | 08:49 PM
nykuryu's Avatar
Default bike fell over....no oil pressure....
some ******* knocked over my bike and no theres like no oil pressure and i can barely start it.
Old Apr 16, 2010 | 09:30 PM
mariof's Avatar
does it say theres no oil pressure after its started? its regular for a bike to say no oil pressure when its cranking. i would say the carbs were knocked a bit and are not adjusted properly anymore.
Old Apr 16, 2010 | 09:33 PM
dyracuse's Avatar
could have oil in the carbs too, a power washer at work got oil in the carbs and air filter, so check the air filter, if that has oil, clean it and then pull and clean the carbs.
Old Apr 16, 2010 | 09:44 PM
Kuroshio's Avatar
Bike goes over, it may not want to "simply start". I'd be surprised if it does.
  • Check the oil (ignore the dash).
  • Check the battery voltage (you may have drained it trying to get it to start)
  • Check the plugs for oil (bike goes over, fluids go everywhere)
  • Check the air box (see above about fluids)
  • Hit the starter a couple times while the plugs are out (warning: be prepared for a mess if she really needs to "clear her throat")
Old Apr 16, 2010 | 11:31 PM
Sand.Man's Avatar
PULL YOUR SPARK PLUGS!
Your cylinders could be full of oil, and if you crank it over with a cylinder full of oil or gas you are going to bend a rod!
Old Apr 16, 2010 | 11:38 PM
Kuroshio's Avatar
That's why I said to hit the starter while the plugs are out and be prepared for a mess
Old Apr 17, 2010 | 12:19 AM
Sand.Man's Avatar
Just thought I would add the ALL CAPS!!!!!!!! To get the point across, haha...
He says he has already tried cranking it over, I'm assuming without pulling the plugs.
I hope there's no serious damage!
Old Apr 17, 2010 | 10:44 AM
nykuryu's Avatar
well she ran yesterday for a bit. im charging the battery right now. ran good so i dont think anything major is dicked up. thanks for all the input tho. if anything else is amiss then ill hit you guys up again.
kgarrison4420
Mar 29, 2010 09:05 PM
paulb51
Mar 23, 2010 07:18 PM
kgarrison4420
Mar 20, 2010 04:16 PM
MikeInCtown
Sep 1, 2009 04:37 PM
maldy21
Sep 2, 2008 02:23 AM
