backfire
Old Nov 14, 2010 | 11:54 PM
RedBaron's Avatar
Originally Posted by gpfan1
jet kits are about $100. But, I've read you can buy some small washers (Radio Shack) and shim up your stock needles. This will richen up your mixture. No one has said how many of the washers is the magic number, but in my jet kit, they added one washer. Maybe two would do the trick. Depends on the thickness of each washer. It works like the adjustable needles in the jetting kits.
Changing the pilot jet to richer will only do so much. It will help with starting and lean surge when cruising, but will not richen up your main jetting like shimming or re-jetting your carbs. You can also buy the next size up from stock(130) and try that too.
You can get jets here.
http://www.cyclewareables.com/pages/..._slow_jets.htm
I have tried shimming the needles up with 1 washer that i took out of my spare set of carbs, hasn't made much difference. I would put another in but i can't find any washers the same size, don't think we have radio shack over here.
Old Nov 15, 2010 | 01:42 PM
gpfan1's Avatar
check electronics outlets or a nut and bolt supply. Shimming is like an adjustable needle, it only helps to smooth out minor issues.
89cane
Dec 14, 2012 11:14 PM
CaliKush
Apr 27, 2009 07:48 PM
stealthcbr
Sep 13, 2005 01:08 AM
stealthcbr
Sep 8, 2005 02:56 PM
bluebowtie
May 4, 2005 07:39 PM
