94 clutch/trans issue
Old Mar 10, 2011 | 04:01 PM
bangin96z24's Avatar
Default 94 clutch/trans issue
just picked up this basketcase 94 f2. got it mostly together, got it running, and now i have an issue.
when in neutral, if your let the clutch out, there is a loud thunk/knock. almost sounds like a motor knock. until you pull the clutch in, and it goes away. havent tried it in gear, but im assuming its the same. still needs more work, sprockets/chain etc put on before i wanna give that a try..
i do have a spare 92 f2 motor that came with it, but its tore down.
any ideas on what the issue could be? really wanna get it running before spring.
Old Mar 10, 2011 | 05:52 PM
switched's Avatar
I've got the same problem here. But in gear, the sound goes away either because:
1) I have the clutch pulled in
or
2) I go above 2k rpm and the knocking goes away.
Another member has the same issue, and he said it's never had any negative impact to his riding, even on trackdays.
I plan on opening up the clutch cover and taking a look at the clutch plates to see if there's anything there...
Old Mar 10, 2011 | 07:22 PM
yeah i think im gonan get it together the rest of the way and see what it does. really wanna get back to stunting this year, and i wont do it on my mint 954
Old Mar 10, 2011 | 10:45 PM
buickid's Avatar
From what I've read, the F2's are prone to making noise in neutral with the clutch out. It doesn't seem to be a problem though.
Old Mar 17, 2011 | 08:58 PM
alright. more info. got the bike together and took it for a ride today. when in gear, you can steal hear the clunking. it almost feels like something in the trans is catching. its dragging bad.
Old Apr 2, 2011 | 01:27 PM
ok. i fixed it. once i tore it down, i realized the shift fork was bent. causing the gears to mesh when they shouldnt. tore my spare motor down, theived the transmission from it, bought a new shift fork, put it all together yesterday.
i must say, for 400 bucks for the bike 82 for the shift fork, 6 hours of work, and 40k miles, this is one hellified running beast of a bike
Attached Thumbnails 94 clutch/trans issue-cbrf22.jpg
Old Apr 3, 2011 | 03:17 AM
switched's Avatar
Super awesome, glad things are up and running for you!
Old Apr 4, 2011 | 10:13 AM
Monkeybutt2000's Avatar
That looks great! What tail section is that??
Old Apr 4, 2011 | 11:29 AM
cant remember which size, but its off of a 70s model honda cb.
nhf3rider
Aug 19, 2011 04:49 PM
jaCo
Jul 6, 2011 07:10 PM
f3 fighter
Jun 23, 2011 04:52 PM
Jopel
Jun 8, 2011 07:13 PM
stoneguy1037
Jul 25, 2008 05:39 AM
