Clutch issue
Old Jun 22, 2011 | 06:19 AM
f3 fighter's Avatar
Default Clutch issue
The clutch on my 1996 f3 does not grab until I let the clutch all the way.my question is is that something I can fix by adjusting the clutch cable?
Old Jun 22, 2011 | 07:43 AM
spicymeowmix's Avatar
Official Welcome Crew Spicy Cat
the lever is adjustable
so is the clutch cable both at the handlebar and down near the basket
Old Jun 22, 2011 | 08:12 AM
blwnstang02's Avatar
This is how mine was when i got it. I adjusted a little at the top on the handle so far and its better. I do need to pull the plastics and do it down on the clutch side.
Old Jun 22, 2011 | 10:58 AM
f3 fighter's Avatar
how far should i adjust it
Old Jun 22, 2011 | 11:14 AM
To where it is comfortable for you as long as the cable adjustment is allowed.
Old Jun 22, 2011 | 10:30 PM
f3 fighter's Avatar
i adjusted the clutch and now its perfect. he had it so tight the clutch was probably alway slightly engaged. thanks for the help
Old Jun 23, 2011 | 10:03 AM
rabbitae86's Avatar
was just about to ask the same question. Mine is the same way. Its about 75% of releasing the clutch before it engages.
Old Jun 23, 2011 | 11:35 AM
f3 fighter's Avatar
what i did was release the bottom clutch cable adjustment nut and let the linkage go slack and then pull it just tight enough little by little untill you have the right amount of play at the hand clutch with i think is between 3/4 and 3/8". sombody jump in if i gave bad advise
Old Jun 23, 2011 | 03:46 PM
rabbitae86's Avatar
sounds good I'll try and do this when I get home from work. Thanks f3 fighter!
Old Jun 23, 2011 | 04:52 PM
MadHattr059's Avatar
Basically, 1/4 to 3/8" free-play at the lever. As soon as you take it up it should start to pull on clutch. That assures that the clutch fully disengages without lowering the reaction time/control of the clutch lever.
Ern
Nick Smith
May 1, 2013 01:19 AM
sjona2011
Jul 7, 2012 04:16 AM
amerce
Aug 21, 2011 07:06 AM
jaCo
Jul 6, 2011 07:10 PM
Panic Button
Jul 20, 2008 10:16 AM
