White Rust???
White Rust???
I recently put on my new 2 Bros exhaust on my F4i and have been in Texas for the past month enjoying the warm weather down here. With the warmth and being fairly close to the coast, i have noticed that on some mornings when there has been dew in the air, my exhaust has what I call "white rust" on it from the moisture. I tried using a silver polish to remove it, however it still has a look like it has water spots on it. I called 2 Brothers and explained it to them, and they told me to try to contact a auto detailer to see what could be used to brighten up the finish. Thought i'd post here to see if anyone else has experienced this and what you used? TIA!
RE: White Rust???
+1 on the Mothers polish.
And if it's REALLY bad you might be able to use some fine steel wool to knock the bad stuff down. I have used steel wool on mid-pipes and rotors, but not on the titanium canister. Yosh gives you a small brillo-type pad to re-buff the Ti and get it back to the factory look. So I am sure steel wool won't hurt anything...
RE: White Rust???
ORIGINAL: jjkukla
Good Luck!
-John
