Detailing Discuss detailing your ride within.
BAD IDEA ???
Old Sep 8, 2007 | 05:47 PM
jwp6114's Avatar
Default BAD IDEA ???
Is using a presure washer a bad idea to clean rims and undertail?
Old Sep 10, 2007 | 03:29 PM
fusor's Avatar
Default RE: BAD IDEA ???
I would probably not do that-- pressure washing your wheels may send some water into your wheel bearings and could maybe even rip the rubber boots inside your calipers--- get a good wheel cleaner-- i like eagle one- and spray your wheels and and use a fine brush on it--- then use a regular hose to spray them off--- it works pretty good-- and if you can use compressed air around your hubs to get some of the water out
Old Sep 17, 2007 | 01:37 PM
Rubicon on 38s's Avatar
Just don't hold the nozzle right next to your bike and its perfectly safe.
Old Sep 17, 2007 | 02:03 PM
Blue Fox's Avatar
Retired Moderator
We have a pressure washer, but I'm not really comfortable using it. It does work wonders cleaning the chain though.
Old Sep 18, 2007 | 03:32 AM
NeverL8's Avatar
whatever you do just dont use the pressure was on anything you painted. even powder coated rims. rock chips can start big peels. your bike shouldn't be that dirty anyway. they got bikes for that already, dirtbike. lol. ride and wash safe.
Old Sep 27, 2007 | 11:28 AM
Ruftags's Avatar
I have never had a problem. I stay approx. 18 inches away with the tip and NEVER spray in the intake tubes.
Old Sep 29, 2007 | 07:28 PM
willklee's Avatar
i just happened to read this on my honda manual right now:
"the o-rings (on the chain) can be damaged by steam cleaning, high pressure washers, and certain solvents... do not brush the rubber o-rings. brushing will damage them. use of a solvent may also damage them."
but, reading this thread and others, it sounds like everybody does at least one of these. is it ok to do this as long as your careful?
this is from a 2004 cbr 600rr manual. i was reading this because i wanted to know if i should clean my chain, and how.
rob_96
Jan 10, 2013 01:30 AM
XHayabusa
Mar 14, 2011 02:11 AM
Orangebutter
Oct 9, 2008 10:16 AM
Raven
Mar 9, 2007 10:23 PM
PitbullF4i
Nov 27, 2006 09:00 PM
