what do you think about this idea??
i was thinking since i hate the rear stand that goes under the swing arm, i much rather spools, i was thinking of getting 2 3 inch bolts that would fit snug into the hollow axel and have them sticking out a half inch and use a stand for spools ..since i already have one?? im going to try it ...what do u guys think??
it most likely wouldn't get the rear tire off the ground since the axle is a good bit higher than spools mounted under the swingarm would be
might as well try though
oh yeah, you obviously wouldn't be able to remove the wheel so if it does work, it'd only be for storage
the pads are just fine for storage...they are plenty stable...
unless you have some ghetto rigged stands...
i have handy stands...and put the bike on there in like 5 seconds...i could probably do it in 3 seconds with spools but 2 seconds isn't that big of a difference to me.
You can just install swingarm spools if you use the inserts... click here.
I ride with a guy that did it to his 05 F4i and it looks great and he hasn't said anything bad about it. I can ask him questions if you likes... just PM me.
