Detailing Discuss detailing your ride within.
Aftermarket non painted pieces - any way to get rid of scratches?
Old Aug 23, 2012 | 01:37 PM
kevinc's Avatar
Default Aftermarket non painted pieces - any way to get rid of scratches?
I ordered one of the aftermarkey fairing kits about 2 months ago, all the painted pieces were good enough, but all of the non-painted pieces are really scratched dur to not being individually protected (all in a jumble scratching each other the entire trip). They sent me another set of non ainted pieces - but did the exact same thing and the second set are even more scratched than the first.
Does anyone know fo a way to clean up these scratches so the piece looks OK? (I am mainly concerned with the 2 RAM Air covers that are outward facing on my 2001 929RR)
Attached Thumbnails Aftermarket non painted pieces - any way to get rid of scratches?-929ramair.jpg
Old Aug 23, 2012 | 07:19 PM
jeffjones's Avatar
Get a can of gloss black Krylon plastic paint and sand them down to smooth and hit it with a couple coats and then some clear and it will look awesome.
Old Aug 23, 2012 | 07:35 PM
kevinc's Avatar
I had thought about paint, but was not sure if it would end up cracking under the twisting and such that this piece can have sometimes.But I do remember that some paints do not have this issue. Thanks for the reply
Old Aug 24, 2012 | 06:17 AM
jeffjones's Avatar
Krylon Fusion for plastic ($4 a can) and some clearcoat is perfect for it as it is designed for plastic and needs no primer (Be sure to spend extra time on sanding).
I did mine at the beginning of last season and no signs of cracking at all.
Old Sep 17, 2012 | 05:07 AM
b-sic's Avatar
Krylon is cheap and can get the job done. But when you no longer want that powdered finish and want it to shine line a candy apple then get yourself an hvlp gun(they become quite useful) apply polyurethane, wet sand, repeat. you can find some sick colors and even get it in a pearl or a metallic.
Old Apr 13, 2013 | 02:09 PM
wheelnut's Avatar
Welcome Crew
if you dont want to paint you could try this
but be careful
Zero1080
Jun 26, 2009 11:52 AM
thisismyacct
Jul 12, 2008 01:59 AM
some guy #2
May 5, 2008 10:28 PM
dsfnuttz
May 1, 2007 08:45 PM
Minhtin
Jul 13, 2005 03:26 AM
