wiring HELP!!
does any body in the forum has a lockhart phillips integrated led blinker and tail light. I was wondering if I could make nit work without the turn signal connectors because the previous owner cut them off.
...... huh? Which turn signal connectors? wiring harness side or tail light side? i have all aftermarket signals and i had to cut the connectors and us dissconnects for them, usually the easiest way. Need some more info to give you an answer though.
