will a 954 stator work on a 929?
Old Jun 12, 2011 | 06:29 PM
J0HNDiLLiNGER's Avatar
Default will a 954 stator work on a 929?
jus picked up a 929 & its not charging, it only geting 10.5v. now i have a extra 954 i use for parts & i want 2 use that stator. it looks like it will mount right on but wut about evrything else?
besides that do any of u know wer to look for a good low price stator?
Old Jun 12, 2011 | 06:36 PM
moosestang's Avatar
All stators for Hondas are cheap compared to my buell. HD wants over $500 for a freaking stator.
I would look on ebay. Aftermarket stators are just over $100, not that much.
I do not know if the stators are the same, but be certain they are before trying it. If it's just a little bit bigger, wider, you will be shopping for a new rotor.
Have you unplugged the stator while the bike is running to test it using a voltmeter? It could be the voltage regulator that's bad.
Old Jun 12, 2011 | 07:49 PM
txsmainevent's Avatar
Nope they are not interchangable. They are different part numbers based off of bike bandit....
Old Jun 12, 2011 | 09:23 PM
christilton954rr's Avatar
i thought that the only thing different in the 954 and the 929 was the bore size?? if thats true the i guess theoretically is would
Old Jun 13, 2011 | 12:46 AM
backdoc's Avatar
I believe a 954 stator will work on a 929 but you have to also replace the stator cover with the 954 cover.
Old Jun 13, 2011 | 09:55 AM
+1
Old Jun 13, 2011 | 03:58 PM
i got alot of bad feedback on an aftermarket stator, so that made me scared to buy 1. i jus dumped so much money in my 954 im tryin to not spend too much on this 929 & the cheapest oem stator i found is $300. so i was curious if any1 knew from experience on a good aftermarket stator & if they could send me a link.
we did check the regulator, my buddy has a 929 also & i plugged his regulator into my 929 & got the same result, must be stator!
im not gona mess with the 954 stator cuz if it dont work ill be spending a $100 on oil when i could jus put it towards a new stator, so if any knows of a good aftermarket stator send me a link.
thanx alot guys u ROCK!
Old Jun 13, 2011 | 05:48 PM
moosestang's Avatar
Why not have the stock stator rewound? Custom rewind in Alabama will rewind your stator for just over $100. They are rewind the buell stators for $140 shipped and doing it in just a few days. Give them a call.
http://www.customrewind.com/
I'd still recommend testing it with a voltmeter before removing it.
Old Jun 14, 2011 | 10:50 AM
im kinda new with the voltmeter, but i only got 10.5v with both regulators, i was told i should get between 13 & 15v. if thers some other way let me know.
thanks for the link
shidosuru
Aug 28, 2010 07:29 PM
slutty62cont
Aug 14, 2005 01:06 PM
slutty62cont
Aug 14, 2005 03:11 AM
