Regulator rectifier question
Old May 29, 2011 | 02:15 AM
ajzcamaro's Avatar
Default Regulator rectifier question
Does anyone know if the 954 and F4i have the same regulator rectifier? I have a spare RR for the F4i and wanted to see if it would work on the 954 so that I could diagnose my hot starting problem.
Old Jun 17, 2011 | 06:31 PM
ajzcamaro's Avatar
So does anyone know if these two RR's are interchangeable?
Old Jun 17, 2011 | 07:03 PM
Conrice's Avatar
they're different part numbers, so i'd say they are not the same - but R/R's pretty much do the same thing, so i'd say you could use it - you'd just have to modify the plugs if they aren't the same by cutting the plug connectors off both R/R's and splicing the 954's plug onto the f4i's R/R to make it work, and then you'd have to figure a way to mount it if you wanted run the 954 with a f4i R/R
but whats the issue you're having? it could be something else too
Old Jun 17, 2011 | 10:48 PM
ajzcamaro's Avatar
I posted another thread about the starting problem. The bike won't start after it gets above 215 degrees.
Old Jun 17, 2011 | 11:28 PM
Piranha's Avatar
Almost any rectifier will work, as long as the fittings are the same..... you could make a rectifier if you wanted.
Old Jun 18, 2011 | 12:52 AM
fragoso87's Avatar
how do you make your own?
Old Jun 18, 2011 | 12:40 PM
Piranha's Avatar
All a rectifier is, is four diodes set up into a wheatstone bridge pattern. It takes AC voltage and turns it into a DC voltage. If you set it up in the Dimond shape, have all the negative sides on the right side, and apply a AC voltage to the top and bottom. Then DC voltage will come out on the left and right.
*Note polarity
pacojoseph
Apr 15, 2013 02:51 AM
cbrgirl82
Jul 31, 2012 02:04 PM
bigape
May 14, 2008 08:40 PM
CBR1987Yellow
Nov 8, 2007 02:09 PM
CBR600F4i2005
Jul 14, 2007 10:39 PM
