What oil filter size
Old Apr 3, 2012 | 03:31 AM
Hudson's Avatar
Default What oil filter size
I have seen one of these filter removal tools on fleabay, its size 68mm, would this fit over our oil filters ?
Old Apr 3, 2012 | 08:44 AM
Conrice's Avatar
don't waste your money...
grip and rip with a big set of pliers (channel locks), or hammer a screw driver into the side of the oil filter, use it's leverage to loosen it, and take it off by hand.
as for going on, id go as tight as you can with your hand, and then (being careful with the channel locks) tighten it a little bit more
Old Apr 3, 2012 | 11:38 AM
letsride's Avatar
Just get the pliers,they are adjustable.
Old Apr 3, 2012 | 11:54 AM
74demon's Avatar
if you want the tool, buy it local. most auto parts stores carry them, and theyre not expensive. fit it to the filter in the store. you also can get some filters, k&n i think, that has a built on nut to loosen it, but those can get pricey.
the pliers is going to be your best bet, imo. plus, you can use them on just about any filter you run across.... like your car, for example.
jbomb
Jul 15, 2013 01:55 PM
jblair626
Apr 13, 2013 12:20 PM
c_keeton600f4
Dec 28, 2009 02:43 PM
usndocjaysin
Sep 21, 2007 10:18 AM
CBRider206
Jul 5, 2006 10:39 PM
