weird problem any thoughts appreciated
Old May 14, 2007 | 07:13 PM
anthony954's Avatar
Default weird problem any thoughts appreciated
I have a 954 wtih 4000 miles and it just started this problem. Cruising at low speeds it misses, under hard braking it dies, The clock will reset going down the road, and hard as hell to start. the battery is fine i tested it with a multimeter and a load tester. I will try to catch the code it flashes next time i see it.
Old May 14, 2007 | 07:54 PM
silvr002001's Avatar
Default RE: weird problem any thoughts appreciated
just a guess, maybe a coil?
Old May 14, 2007 | 09:12 PM
VP's Avatar
VP
that has to be something electrical...possibly " hot" wiring or maybe a coil like silvr said
Old May 14, 2007 | 09:48 PM
outsider8's Avatar
just guessing!!-check all the ground points and inspect connectors(pull them apart to check!!)
hopefully something simple!!!
good luck
o8
Old May 15, 2007 | 02:02 AM
anthony954's Avatar
ok the light just stays on til the problem ends so I guess that would be the code....I just bought this in November brand spankin new and still has factory warranty...so I am worried that ths electrical problem will probably not be covered anyone have any experience with warranty
Old May 15, 2007 | 07:50 PM
factory extended warranty means anything that is defective and does need to be replaced because of "normal wear and tear". What your describing sounds like (if something is not loose) a defective piece but you just wont know till you go to a honda shop
Old May 15, 2007 | 09:48 PM
richhowerton's Avatar
Take it back to Mother Honda if it is covered do not mess with it. But it sounds like a bad ground or a worn wire and when you hit the brakes somthing shifts hitting it killing the bike
Old May 18, 2007 | 05:21 PM
anthony954's Avatar
it was just the battery lead had vibrated loose so im glad i didnt take it to the shop
Old May 18, 2007 | 09:44 PM
outsider8's Avatar
i'm glad to hear that you got the problem worked-out,without having to spend $$
sounded like a connection problem of some sort-but who knows??,with what
you posted as the problem-"all bets are off!!!"
anyway cool you found it!!Name:  thumbup.gif
o8
Medic89
May 5, 2014 09:42 AM
esoracco
Jul 29, 2010 11:10 AM
Mr.S7
Jun 4, 2009 01:34 AM
benr
Oct 1, 2008 02:18 PM
laybac
Jun 7, 2006 08:28 PM
