Turn Signal Problems!!!!
Old Jun 11, 2010 | 11:26 PM
Mondstar77's Avatar
Default Turn Signal Problems!!!!
This is the set up and the problem. The bike has bulbs for the front turn signals and leds for the rear. The problem is that the left side lights (as you are setting on the bike) stay on but when I use the left blinker they work. The right side, when I use the blinker only the rear led works and the front goes out. Some times the right blinks and some times it just stays lit or blinks so fast until it looks like it stays lit. Please help me???
Old Jun 13, 2010 | 01:01 PM
txsmainevent's Avatar
Have you taken the bike apart? are the signals up front aftermarket? are the fronts set up to run as day time running lights?
Old Jun 13, 2010 | 05:40 PM
Conrice's Avatar
i know the right side turn signal problem is the resistor for the rear LED is going bad. you need a 5 ohm resistor for it (same thing happened to me a few months ago).
you could just add another incadescent bulb to the circuit (that's what i did). Above each of the bright lights in the front, there is a slot for another turn signal. it looks cool, adds a bit of functionality to your bike, and doesn't really cost any more than buying another resistor.
on the left, does your rear LED stay lit up, or is it just the front that stays lit up? did this just start happening, or has it been going on since you got the bike? if you're using the stock turn signals and its only the front that stays on, it's probably just the running light wire is still hooked up. you should have a ground hooked up, and a LT wire hooked up, and there should be a third wire that's for running lights. if you dont want it, unplug it and cap it.
Old Jun 17, 2010 | 07:10 PM
Mondstar77's Avatar
Thanks. Will try what you said and let you know if it works. Fingers crossed.
Old Jun 18, 2010 | 01:15 PM
Mondstar77's Avatar
Thanks Conrice!! It worked. It was the daytime running lights. I unplugged it and it's all good. Thanks everyone for everything!!!!!! You guys are the greatest.
flyinpoon
Jan 25, 2012 04:52 PM
illy600
Apr 30, 2010 06:38 PM
diguise88
Apr 6, 2010 03:14 PM
oldwhite600
Aug 19, 2009 09:41 AM
RockStaRR
Jun 21, 2007 04:51 PM
