F4i turn signal problems
Old Mar 16, 2010 | 11:45 PM
diguise88's Avatar
Default F4i turn signal problems
so i wanted aftermarket turn signals so in my stupidity i used a dremmel to widen the stock turn signal hole to fit the ones i bought. due to clearance issues i couldn't make them fit. i was wondering if these
http://cgi.ebay.com/ebaymotors/Turn-...Q5fAccessories
...would cover the hole up that i have. any suggestions would be helpful. thanks
Old Mar 17, 2010 | 04:26 AM
teko1020's Avatar
What exactly did you do? Did you sand off the center of the mounting holes to enlarge those or did you actually cut out the section where they are mounted?
Old Mar 17, 2010 | 11:56 AM
Incognito's Avatar
Official CBRF Welcome Crew Undercover Agent
Yep, without pictures, it's hard gauge the amount you took off. You may consider filling-in the hole you cut with fiberglass, rather than covering it up.
Old Mar 17, 2010 | 01:12 PM
gotcbr's Avatar
Had a similar problem. I put a big washer on the backside. Worked like a charm. I'm running Hotbodies LEDs that fit in the signal indent/recess. Unless you completely cut out that indent, you should be able to do what I did & use just about any type.
Good luck.
Old Apr 6, 2010 | 03:14 PM
diguise88's Avatar
im afraid i cut the recessed part out to fit the ones i bought. Instead of the two holes that should be there stock i have one large hole. I might just have to take the washer approach. Any other ideas would be welcome
flyinpoon
Jan 25, 2012 04:52 PM
Meanf3i
Aug 15, 2011 10:01 PM
illy600
Apr 30, 2010 06:38 PM
oldwhite600
Aug 19, 2009 09:41 AM
RockStaRR
Jun 21, 2007 04:51 PM
