tip toe
Old Nov 11, 2008 | 02:04 AM
jsuar039's Avatar
Default tip toe
i recently got a 954 but have not had the chance to ride it because its been painted, my problem is that when i sit on the bike i cant plant both feet on the ground. i was wondering if anyone else has this problem and i was wondering if lowering the rear will alter the performance or handeling of the bike in any way?
Old Nov 11, 2008 | 08:47 AM
txsmainevent's Avatar
Default RE: tip toe
If you lower the rear please lower the front also! I think it is pretty lame to see a sportbike sitting low in the rear and high in the front. It is simple to lower the front to match. Also you can try softening your suspension, ive heard of shaving some of the foam from the seat but I dont see more than a 1/2' difference.
Old Nov 11, 2008 | 01:01 PM
jsuar039's Avatar
Default RE: tip toe
my brother was the previous owner of the bike and he had previously lowered the front and said that it didnt handle too good, and when i sat on it id didnt make much of a difference but ofcourse ill lower the front if i lower the back it does look ****ty otherwise.
Old Nov 11, 2008 | 10:57 PM
RCR's Avatar
RCR
Default RE: tip toe
Here ya go
Old Nov 12, 2008 | 12:36 PM
jsuar039's Avatar
Default RE: tip toe
funny...
Old Nov 12, 2008 | 12:39 PM
TheX's Avatar
Default RE: tip toe
ORIGINAL: RCR
Here ya go
perfect!
Old Nov 12, 2008 | 12:48 PM
TK954RR's Avatar
Jan 2009 ROTM
Default RE: tip toe
Cripes, may need some adjustable rearsets to be able to shift though.
Old Nov 12, 2008 | 12:53 PM
TheX's Avatar
Default RE: tip toe
Well, there is that.
Old Nov 12, 2008 | 05:39 PM
VP's Avatar
VP
Default RE: tip toe
You can get a reverse gear to help out if that's the issue
Old Nov 12, 2008 | 05:45 PM
TheX's Avatar
Default RE: tip toe
VP, your bike is dead secksi...just had to say that.
