TANK SLAPPED
RE: TANK SLAPPED
Ohlins is the **** but if its happening at every corner you need to check your suspension. Make sure both forks are set the same and the front wheel is balanced. I know the 929's and 954's are easily upset but by no means should it be that back. Something is seriously messed up with your suspension from the sounds of it. If you need a damper go the ebay route you can always find them on there for the 954's.
