TANK SLAPPED
which is the best damper for 954. i am tired of been tank slapped at every corner exit where can i get it and for how much:(
RE: TANK SLAPPED
Scotts
about $300-400 |
RE: TANK SLAPPED
get the forks revalved and resprung
RE: TANK SLAPPED
Ohlins is the **** but if its happening at every corner you need to check your suspension. Make sure both forks are set the same and the front wheel is balanced. I know the 929's and 954's are easily upset but by no means should it be that back. Something is seriously messed up with your suspension from the sounds of it. If you need a damper go the ebay route you can always find them on there for the 954's.
RE: TANK SLAPPED
scotts/ohlins..
RE: TANK SLAPPED
i love scotts, very adjustable and good quality..
RE: TANK SLAPPED
Buy my gold scotts for $250 and I will buy a new GPR Scotts are great but all stunters and track guys I talk to love the new GPR the best!
RE: TANK SLAPPED
I am very satisfied with my Storz.
RE: TANK SLAPPED
fix the problem-dont put a band-aid on it,your saftey is of the essence
edit-if you must-ohlins and also if you are having a heat problem(india)-i would also recommend installing the damper update kit-go to ohlins website for/about this!! good luck |
RE: TANK SLAPPED
^[sm=icon_ladiesman.gif]
