TANK SLAPPED
Old 07-26-2007, 01:57 PM
sun_bxs's Avatar
Default TANK SLAPPED
which is the best damper for 954. i am tired of been tank slapped at every corner exit where can i get it and for how much
Old 07-26-2007, 02:34 PM
TEN's Avatar
TEN
TEN is offline
Default RE: TANK SLAPPED
Scotts
about $300-400
Old 07-26-2007, 02:38 PM
get the forks revalved and resprung
Old 07-26-2007, 02:45 PM
Triax's Avatar
Ohlins is the **** but if its happening at every corner you need to check your suspension. Make sure both forks are set the same and the front wheel is balanced. I know the 929's and 954's are easily upset but by no means should it be that back. Something is seriously messed up with your suspension from the sounds of it. If you need a damper go the ebay route you can always find them on there for the 954's.
Old 07-26-2007, 04:42 PM
scotts/ohlins..
Old 07-26-2007, 05:11 PM
bobjoezx's Avatar
i love scotts, very adjustable and good quality..
Old 07-26-2007, 06:00 PM
Buy my gold scotts for $250 and I will buy a new GPR Scotts are great but all stunters and track guys I talk to love the new GPR the best!
Old 07-26-2007, 07:09 PM
TK954RR's Avatar
Jan 2009 ROTM
I am very satisfied with my Storz.
Old 07-26-2007, 07:53 PM
fix the problem-dont put a band-aid on it,your saftey is of the essence
edit-if you must-ohlins and also if you are having a heat problem(india)-i would also
recommend installing the damper update kit-go to ohlins website for/about this!!
good luck
Old 07-26-2007, 08:20 PM
^[sm=icon_ladiesman.gif]
Quick Reply: TANK SLAPPED
