Slight oil leak, new rider need help!
Old Jul 6, 2009 | 11:46 PM
skydryice's Avatar
Default Slight oil leak, new rider need help!
Hi guys, I just picked up a 03 954 RR and rode it for couple days.
I recently noticed some oil collecting on the bottom side of the fairings where they join. Whenever I let it sit after riding, I puts couple drops on the pavement... I checked and it seems like it is coming from the set of bolts above the oil pan. Not the oil pan, but the ones above it...
I couldn't find a gasket for it online, Is there a gasket there? What could be leaking? The oil level is normal (between the lines). What should I check for?
Thanks for your help!
Old Jul 7, 2009 | 12:05 PM
theskater101388's Avatar
go to bikebandit.com, look up the bike under OEM parts and there are diagrams of the bike with every part possible. if you dont find a gasket on there then there is none.
Old Jul 10, 2009 | 02:35 PM
apcycles's Avatar
if you are refering to the case bolts there is no gasket between cases but if its leaking bad enough to enoy the **** out of you pull the motor out drain all the fluids, flip it upside down take apart the cases use fresh hi temp silicone put the cases back and tight them to specs. about 3 to 4 hours of job... good luck
Old Jul 10, 2009 | 08:02 PM
skydryice's Avatar
found the leak is actually from the stator cover gasket. new gasket on order.
Old Jul 11, 2009 | 12:01 AM
chasesdaddy01's Avatar
I have had many..many 929,954,f4i come thru the shop with the same problem...most of the time it was a preowned bike that was dropped on the stator side and the cases were broken and not welded back together flush so that there isnt a leak...when you pull the stator cover check that the cases around the cover werent tampered with or rewelded by some dummie before you. If it is you can have it rewelded(expensive and can cause case warping) or put two gaskets in there instead of one.
Gotpepsi
Apr 10, 2010 10:23 PM
NYKnick1015
Aug 4, 2009 11:06 AM
cbr600f217
Jul 18, 2008 09:17 PM
Chunky
Aug 18, 2007 11:50 AM
Ar15 guy
Oct 1, 2006 10:39 AM
