problem with starting
Old Jan 5, 2009 | 08:09 AM
bajaroots's Avatar
Default problem with starting
Whats up fellas my brother owns a 929 withhigh milage ,the bike runs great but recently upon start ups sometimes the solenoid kicks in (that whizzing noise before you hit the start button)and sometimes it dont ,he has to keep turning on and off the kill switch untill he hears that whizzing noise ,and even after that it will crank but will not start like its not getting any fuel. Eventually it will start after turning up the idleand a few trys.Rule out bad gas weve rode a few hundred miles and been thru a few tanks in a day anyone had the same prob.
Old Jan 9, 2009 | 09:35 PM
xtreme954rr's Avatar
Default RE: problem with starting
the whizzing sound is the fuel pump it should sound every time you turn on the ignition key and kill switch,if not hearing sound every time then the battery is low or bad conection at battery or fuel pump conection under the seat ,two plug green conector,or bad fuel pump relay or bad pump,do a fuel pump flow test,very easy,good luck.[sm=nxsmile.gif]
dirtyhall
Apr 15, 2011 08:41 AM
CBRPutty
Aug 12, 2010 09:04 PM
dgraviett
Jul 14, 2009 10:59 AM
whtan20
Nov 25, 2007 01:36 AM
ITZOBIG
Apr 14, 2007 11:56 AM
