plate flipper help
Hi guys, I just installed my plate flipper from www.plateflipper.com. Itworks great, but Idid something wrong along the way . My tail light, andcluster( no rpm,speed etc) doesn't work. I noticed my fuse was burned, so I changed it and it got burned again as soon as I turned my ignition. What am I doing wrong???Thanks for any help.
You've got a short somewhere. Most likely in the tail area where you mounted the plate flipper. Check the area where you screwed and bolted stuff together and make sure you didn't pinch, cut or ground out any wires.
