No spark!
Wiring harness has been taken off and back on a couple times during a buggy build. Fuel pump is priming. Injectors are firing (you can smell it). The engine ran the day before I tore it all down. But now I got no spark. As best I can tell everything is plugged in (pulse generator and cam sensor). The tip sensor has been bypassed (red wire to ground). I have tried two kill switch assemblies (both known working). I have tried two key switch assemblies (one known working, one I'm pretty sure works).
Where should I start here?
