Honda 929 no spark
Old Jul 31, 2012 | 12:54 PM
Neil Haywood's Avatar
Default Honda 929 no spark
hi this bike im completely lost with bike was running fine parked it up 1 night and now no spark there is power to the black and white coils 12v checked the kill switch this works fine checked the pink wire 9v all fine checked the stand switch works great stripped the main wire harness and came across a block that had loads of green wires these were ok but there were loads of black and white wires on this block and 1 of em was broken off and the others had green scum on em cleaned and put new connectors on these and still no spark, even the fuel injectors dont work either any idea?????
Old Jul 31, 2012 | 02:31 PM
74demon's Avatar
If you have power then you are missing a ground signal check the ground for the ecu and the cam sensor and pulse generator for signal
does your fuel pump prime?
Old Jul 31, 2012 | 03:00 PM
yeah it primes il check the cam pulse and ignition, it was going fine then i had to bump it to start so i changed the battery and eventually it got worse to how it is now.
BitRex
Sep 13, 2014 09:30 PM
tcsonnigsen
Sep 26, 2013 08:32 PM
Hsimpsons13
Sep 12, 2012 06:15 PM
ihatethisbike
Jul 27, 2011 12:39 PM
harveyjoykill
Oct 16, 2006 04:10 PM
