2001 Honda CBR900RR No Spark
Guest
Posts: n/a
I have a Honda CBR 900RR It was running amazing for a while then about a few weeks ago i was riding and the bike would cut in and out while i was riding. It slowly got worse to the point where it would die just ideling. So i changed the plugs and no spark. Then i proceeded to change the ECM and still no spark. I checked the coils and they are good. I am at a loss on what it could be i am running out of money and need someone to point me in the right direction please help
Moved to the 929 section. In 2001, the "900rr" is a 929rr. It's a completely different bike...
Does your fuel pump prime?
Do your injectors have signal?
Have you checked for 9v at the pink wire on the ignition switch?
Does it have the HISS system?
Is the FI light on?
Did you do anything to the bike right before the problem started?
Did the idle drop so low that it stalls, or did it just shut off?
If your replacement ECM in not brand new, put your old one back it. There is no guarantee that it is any good.
Is the FI light on?
Do you know if the clutch cover has been off the bike recently? Follow the wire coming out the top of the clutch cover to the red plug just behind the frame rail and make sure its plugged in.
army_soles_803
04-07-2010 06:03 PM
MARTINEZ
04-07-2008 12:23 PM
