no brakes!
first post on this name... havent been on here in awhile guys, forgot my old user name...
so when i put my bike away for winter, the brakes worked fine... take it out this spring... my rear brakes garbage!! if i slam the brakes... i have almost no pressure in the back... fronts are fine though.... i bled the rear caliper twice! still same pressure....
this happen to any of you before?
looks good next to the truck though...
My suggestion to you is to make sure you are bleeding the brakes properly.The first time I bled my rear brakes I had the same thing as you,I had to press the brake pedal at least 3 times to get any pressure.The second time I bled them I kept bleeding til I got a hard pedal and make sure you tighten everything back up.Give that a shot and see if you get any results.
thats how my front brakes were after i let it sit for winter. i could squeeze them to the bars even with stainless steel brake lines.
so i bleed them...that was scary when i wasnt able to stop.. yikes.
If you can pump the brakes up then you have a small air bubble. If nothing, ever, then LOTS of air or the MC is kaput.
Bleed the brakes, properly, if nothing then rebuild or replace. I have a rear brake system for sale. PM me if needed.
