Mount for Power Commander (Dynojet) LCD display
Old Dec 22, 2015 | 02:21 PM
kahlilj's Avatar
Default Mount for Power Commander (Dynojet) LCD display
I picked up one of these a while back, but never mounted it to my bike:
http://www.powercommander.com/powerc...rtbike_3_l.jpg
Mine is a PC3 with USB. Does anyone else have one of these installed? If so how did you mount it? or ANY suggestions on how to mount it? I've looked on Dynojet's website and a couple of others, but didn't see a bracket to mount it.
I did see these mounts which might do the trick:
Techmount Motorcycle Fork Tube Stem Power Commander LCD Mount
Amazon.com: Techmount 4-DYNO - Power Commander LCD Adapter: Automotive Amazon.com: Techmount 4-DYNO - Power Commander LCD Adapter: Automotive
and this one:
https://www.dynotunenitrous.com/stor...?idproduct=251
I can't believe how hard it was to search for these, but they both appear to use the same method: attach to the triple bar fork tube. My only concern with that is that if I decide to get a dampener this will be in the way
Old Jan 1, 2016 | 12:25 PM
Marco Marfè's Avatar
sure with the second you will have a problem.a friend of mine has it like this:
or like this would not be bad
Old Jan 3, 2016 | 09:57 PM
kahlilj's Avatar
Those look pretty kool Marco. Thanks for sharing. I decided to get the stem mount, but I would definintely like to see how those are displays mount or attach to the bike. Do you have more pics? or do you know how they attached them?
Old Jan 13, 2016 | 09:56 AM
i know the owner of the 954 yellow i will ask to him and i will let you know (sorry for the late answer)
Old Jan 13, 2016 | 01:00 PM
Conrice's Avatar
What other electronics does that yellow one have? I see toggles everywhere!
Old Jan 15, 2016 | 01:41 PM
here it is how my friend fit on the bike:
Conrice the switch next to the monitor it's for the second map and the little display next to the gauge it's the gear indicator
Old Jan 18, 2016 | 10:38 PM
kahlilj's Avatar
Thanks Marco. So basically just a home made L-shaped bracket drilled with holes to match those of the display? kool! Thanks for sharing that info
Old Jan 26, 2016 | 03:38 AM
you are welcome =), yes it's homemade bracket that match with the display
badboikilla
Nov 18, 2008 07:25 AM
uponone929rr
Jun 30, 2008 08:52 PM
Todd84
Jun 25, 2008 08:24 AM
Todd84
May 16, 2008 01:04 PM
rangerscott
Jul 23, 2007 11:56 PM
