Mount for Power Commander (Dynojet) LCD display
I picked up one of these a while back, but never mounted it to my bike:
http://www.powercommander.com/powerc...rtbike_3_l.jpg Mine is a PC3 with USB. Does anyone else have one of these installed? If so how did you mount it? or ANY suggestions on how to mount it? I've looked on Dynojet's website and a couple of others, but didn't see a bracket to mount it. I did see these mounts which might do the trick: Techmount Motorcycle Fork Tube Stem Power Commander LCD Mount and this one: https://www.dynotunenitrous.com/stor...?idproduct=251 I can't believe how hard it was to search for these, but they both appear to use the same method: attach to the triple bar fork tube. My only concern with that is that if I decide to get a dampener this will be in the way |
2 Attachment(s)
sure with the second you will have a problem.a friend of mine has it like this:
Attachment 27191 or like this would not be bad Attachment 27192 |
Originally Posted by Marco Marfè
(Post 1292978)
http://i1065.photobucket.com/albums/...psbjh34jku.jpg or like this would not be bad http://i1065.photobucket.com/albums/...ps5bu39fi6.jpg Those look pretty kool Marco. Thanks for sharing. I decided to get the stem mount, but I would definintely like to see how those are displays mount or attach to the bike. Do you have more pics? or do you know how they attached them? |
i know the owner of the 954 yellow i will ask to him and i will let you know (sorry for the late answer)
What other electronics does that yellow one have? I see toggles everywhere!
2 Attachment(s)
here it is how my friend fit on the bike:
Conrice the switch next to the monitor it's for the second map and the little display next to the gauge it's the gear indicator Attachment 27151 Attachment 27152 |
(Post 1293225)
Conrice the switch next to the monitor it's for the second map and the little display next to the gauge it's the gear indicator http://i1065.photobucket.com/albums/...psq1sg2egm.jpg http://i1065.photobucket.com/albums/...psq1dbtfxp.jpg |
you are welcome =), yes it's homemade bracket that match with the display
