Mika_U's top case
Probably they wan't to fix the case they screwed up allready. They wan't to see what's gone wrong whit it and that it is for sure the case that they have worked on. And actually i checked and there isn't any for sale at the moment.
It's more than just welding it up and adding some filler aluminum... The hone/hatch isn't what concerns me the most, it's the other damage.
The upper case has been shown to few serious engine builders and they said the main bearing inserts look nasty but the pieces are in percentage so little and allso on the side so they don't really matter as long as they are smoothened out so that they don't lift the bearing up and the oil gallery can be fixed by welding and machining the hole to right size.
But fixing the bearing inserts to how they were before it was screwed is virtually impossible to anybody ellse then big factorys that originally make them. It would have to be welded and bored in line again whit the bottom casing like they were from the factory.
Only thing whit the hones that i'm afraid is that the scratches on the cylinder are too deep that the piston to cylinder wall clearence will go to loose if it's honed again whitout new plating. I could get it honed here but not plated.
Oh, I couldn't agree more. I'd be mad as hell if I was you - and I wouldn't expect to have to pay to fix what they messed up... Let me know what Millennium says to you when they get the pictures you sent them. I can't imagine they wouldn't take responsibility. Especially if you name drop some of your motor building friends - I'm sure they'd work to resolve it real quick
Lets hope that this goes whitout any problems and quick. I will post when i or the shop gets some answer from them. The photos of the damages on the top case was sended week and an half ago and photos of the hones just before i send them to you. They haven't replied to me or the shop yet. So the customer service they have doesn't really get points from me.
You could give them a call and ask what is the problem whit this case? You live there so it would be much easier for you
