Key lock!!!
Old Mar 6, 2008 | 10:56 PM
xcessivemoto's Avatar
Default Key lock!!!
Can anyone tell me how to lock the steering? And yes, I am familiar with how to lock, I pull the bars all the way to the left, push the key down and try to go to the lock position and it won't go to it!
Oh yes, 2003 CBR954RR.
Thanks!
Old Mar 6, 2008 | 11:07 PM
zerochickenstrips's Avatar
Default RE: Key lock!!!
Sometimes after alot of use, the steeringstops (little bumps on the side of the frame neck) will get a little worn. If this is the case, the steering is going just a little too far for the lock cylinder in the ignition to correctly engage the hole in the frame neck. Try turning the handlebars just a little to the right and try the lock again. If this doesn't work, push the key down and put a little pressure on it toward the lock position and fiddle with the handlebars and see if the cylinder will fall into the hole. Alternately, you could always turn the handlebars to the right and lock them in that position.
Old Mar 7, 2008 | 09:41 AM
NY Erion929's Avatar
ORIGINAL: zerochickenstrips
+1
Old Mar 7, 2008 | 10:51 AM
matty's Avatar
exactly! my 54 was dropped before i got here so the little ridge on the frame is pushed back a good ways.
Old Mar 10, 2008 | 03:57 PM
demonchild's Avatar
I would bet that he is using an X265 aftermarket key. It is the one referenced for our bike but needs an extra cut to work with the lock mechansim on the steering.
linwoodc3
Mar 28, 2012 11:25 PM
p1squally
Apr 1, 2010 07:56 PM
Cun0144
Riding Gear
Oct 15, 2008 06:15 PM
Cun0144
Aug 29, 2008 08:53 PM
Jaybird180
Aug 27, 2006 10:54 PM
