i want these!!!
Old Nov 14, 2006 | 09:03 AM
outsider8's Avatar
Default i want these!!!
about $950
i cant afford them!![sm=boohoo.gif]
Old Nov 14, 2006 | 06:16 PM
VP's Avatar
VP
Default RE: i want these!!!
psh yeah ... me too. I'm about 1500 bucks short to get those babies
Old Nov 14, 2006 | 07:13 PM
bobjoezx's Avatar
and why would u spend 950 on that....
Old Nov 14, 2006 | 07:45 PM
VP's Avatar
VP
bobjoezx do you still have your 954? I think I remember reading a while back that you didn't have it any more...
Old Nov 14, 2006 | 09:21 PM
outsider8's Avatar
ORIGINAL: bobjoezx
i have been looking for a stronger lower clamp-this is the only one i have come across
that will work with oem forks-simply put,i want more stability-i have come across
headshake for no apparent reason at higher speedsName:  eyecrazy.gif
Size:  724 Bytes-f*** that,yes i could install
a damper,but that is only masking the problem(basically spring/sag related!!!).
to run with the current models-imo,it is going to take alot of little things done to the front
suspension rather then one major change-$950 is a major change,well at least to my wallet!!
if you know of any aftermarket lower clamp-please ping me with a link!!!
o8
Old Nov 15, 2006 | 11:59 AM
bobjoezx's Avatar
ORIGINAL: vpsophmore
No i dont, you are correct, i sold it because i didn't want it anymore in winter months and i was goin to purchase the 2006 1000RR in FEB right when they came out but i lost my licence and got more tickets and well you all know how that goes so i had to put off owning a bike this past summer, i did put about 2-3k miles on other bikes tho, had fun!
Old Nov 15, 2006 | 12:01 PM
bobjoezx's Avatar
ORIGINAL: outsider8
ORIGINAL: bobjoezx
headshake for no apparent reason at higher speeds-f*** that,yes i could install
o8
O, i c, i had a scotts dampner and it worked great, and only a couple hundred dollars, but i agree with you, just not sure if i would spend 950 when i can spend just 250 on dampner
