i want these!!!
ORIGINAL: bobjoezx
and why would u spend 950 on that....
that will work with oem forks-simply put,i want more stability-i have come across
headshake for no apparent reason at higher speeds
-f*** that,yes i could installa damper,but that is only masking the problem(basically spring/sag related!!!).
to run with the current models-imo,it is going to take alot of little things done to the front
suspension rather then one major change-$950 is a major change,well at least to my wallet!!
if you know of any aftermarket lower clamp-please ping me with a link!!!
o8
ORIGINAL: vpsophmore
bobjoezx do you still have your 954? I think I remember reading a while back that you didn't have it any more...
ORIGINAL: outsider8
i have been looking for a stronger lower clamp-this is the only one i have come across
o8
ORIGINAL: bobjoezx
o8
