I want 180hp on the 954. Suggestions?
Old 11-23-2009, 03:50 PM
racer108's Avatar
Default I want 180hp on the 954. Suggestions?
I have built this absolutely wonderful 954 that handles better than anything I have ridden lately on the track. However great she is in the corners she really lacks on the straights with power. I am sure that some of you have done some engine mods to get more power. So, please offer up any suggestions you might have. This is my winter project.
Old 11-23-2009, 07:24 PM
Hyperionjr's Avatar
You can try gearing instead. A lot cheaper. Pretty much same results for what you want.
Old 11-23-2009, 08:48 PM
PlayfulGod's Avatar
+1 on gearing, to get more power out of the engine will require internal mods.
Old 11-23-2009, 09:43 PM
Red_Eye's Avatar
I saw a dyno graph of an R1 that was stroked back to square, it was impressive to say the least. Also not cheap.
Old 11-24-2009, 03:49 AM
bubba_finch07's Avatar
180hp? maybe a TOTAL engine rebuild,or bolt on a turbo.. either way, not so cheap
Old 11-24-2009, 09:49 AM
racer108's Avatar
I have tried the gearing. This bike is totally setup from head to toe accept for the engine. I found a guy on the rrzone forum selling a carbon fiber ram air system. Nice. I am planning on doing motor mods, I think it is the only way to make good gains at this point.
Old 11-24-2009, 10:10 AM
NYKnick1015's Avatar
i dont think the CF ram air is gonna get you the power you need... correct me if im wrong but 954 already has ram air and getting a CF system isnt gonna make much of a difference than it already is... well minus 3-4lbs, thats about it... start with the motor... if i have learned anything about motors is that the higher the compression, the higher the output (on a NA motor of course) but you also have to have the proper headwork and fuel systems to equate it... that is gonna cost major $$
Old 11-24-2009, 10:26 AM
+1 priced a 1mm overbore piston setfor the 954 and it ran over $600 bucks. O_o i say turbo set-up with a little headwork and custom map
Old 11-24-2009, 11:25 AM
PlayfulGod's Avatar
a turbo may net the desired HP but wont be much fun in the twisties or on a track except for a drag strip!
Old 11-24-2009, 12:01 PM
really? why do you say that?
Quick Reply: I want 180hp on the 954. Suggestions?
