I Dynoed my bike finally
Old Jun 12, 2008 | 10:28 PM
BrewCity954's Avatar
Default I Dynoed my bike finally
127.8 HP on a very humid day last thursday
The guys said it wasn't the best day to run do to the humidity. I have a two bros m-2 bolt on, a/f's were around 13.5 except I had a rich hiccup from 45-60 mph at 11.8. I ran the bike as soon as I pulled into the lot so it was a little hot.
Does this number sound a bit right considering the weather conditions or am I suffering from a lack of power?
Old Jun 13, 2008 | 12:42 AM
doogstar's Avatar
Default RE: I Dynoed my bike finally
I have never been dynoed, but compared to some of the numbers i have seen posted on here, it seems a lil low. Lowest is usually around the mid 130s. Maybe the humidity did play a factor.
Old Jun 13, 2008 | 06:02 PM
Nealio240z's Avatar
149.7 to the tire, -took alot of work
Old Jun 16, 2008 | 01:55 PM
joshr18's Avatar
Hmm, that doesn't seem right. 127HP? Here's my dyno numbers. I don't have a scanner so bare with me.
I got more than that and my bike was off the chart lean when the initial run was done. I have a K&N filter, Two Bros slip-on, and a PCIII.
http://i307.photobucket.com/albums/n...ynoresults.jpg
Initial run yielded 138.6HP and 70.99lbft. of torque
After custom map, results yielded 144.38HP and 74.21 lbft. of torque
Old Jun 16, 2008 | 06:48 PM
I'm going to try and dyno it elsewhere with decent weather to see if I get any different results. Its starting to seem really low now....it only has 9300 miles on it, I replaced the air filter yesterday but the old one wasn't even that dirty.
Even the most modified 1000rr there only put down 141. The rest were around 135-138.
600rr's were putting down 103-104
Old Jun 16, 2008 | 10:29 PM
NastyNINA54's Avatar
120-130 SOME HORSIES SOUNDS DISAPPOINTING. MAYBE I NEED A SUZUKI AFTER ALL........... HAHAHA YEA RITE I LOVE MY HONDER 954.
Old Jun 16, 2008 | 11:32 PM
TK954RR's Avatar
Jan 2009 ROTM
Yea those numbers seem about 10-20 hp off to me.
Old Jun 16, 2008 | 11:53 PM
Nealio240z's Avatar
It could be the dyno... That sems kinda low to me
Old Jun 19, 2008 | 02:18 AM
BikerBoy930's Avatar
Motorcyclist has them at 131 HP brand new and stock. They key here is that they only weigh 370 lb's drynot many bikes that can touch that power to weight ratio.
Old Jun 20, 2008 | 12:58 AM
Nealio240z's Avatar
What do they weigh wet? I have done every weight reduction measure known to man and with my tank full my bike weighs 379
