How do i remove the top speed limiter?
Old Jul 22, 2005 | 08:56 PM
dallas954rr's Avatar
Default How do i remove the top speed limiter?
I want to remove it. Someone tell me how thanks
Old Jul 25, 2005 | 12:20 AM
reevesna's Avatar
Default RE: How do i remove the top speed limiter?
i don't know about your 954 but mine is not limited by a top speed limiter...it is limited by itself...i've only ever seen 176mph before and it has dynod at 140hp with the air filter, exhaust and power commander remapped
Old Jul 27, 2005 | 02:32 PM
bwp777's Avatar
Only a highly modified 954 will run 186 or more. If this is just a slightly modified bike then it won't get close to 186mph.
Old Jul 27, 2005 | 08:17 PM
kahlilj's Avatar
what do you mean by "highly modded"?
Old Jul 27, 2005 | 08:28 PM
sirlimpzalot's Avatar
Highly Modded would be Big Bore, Nitrous, ect...how fast are you trying to go?? AMA Superbikes can go about 195 MPH but the cost $150,000-$250,000 and are purpose built!!
[sm=nxsmile.gif]
Old Aug 8, 2005 | 11:30 PM
VITIATED's Avatar
ORIGINAL: reevesna
176 is that the speedo speed or real speed 954's speedos are off 5%i found that out looking for the speedo healer
Old Aug 16, 2005 | 06:38 AM
rr954ryder's Avatar
mine is geared 7 up and my speedo stopped at 185mph @ 12,000 rpm, the computer wouldn't let it hit the rev limiter in 6th. I was probably only going about 145-150 mph actual
Old Aug 16, 2005 | 09:03 PM
VITIATED's Avatar
ORIGINAL: rr954ryder
how is ur med & low power . i want mine to go read fast but i dont want to lose my low & med either thats y i bought stock gearing . i dont kno any bout gearing sprockets
Old Oct 1, 2005 | 03:28 AM
bobjoezx's Avatar
i have -1 in front and +2 in rear, i can get the speedo saying 183, if i had a little more road/time/guts, i could prob hit 185, but the speedo is prob off, but not that much, about 5-7 mph i think -1 and -2 is a perfect setup, i would recommend trying that setup
guitarhawaii
Jan 11, 2013 05:01 PM
skip4609
Aug 17, 2011 02:09 PM
antatious
F2 Tech
Aug 23, 2010 05:31 PM
Oz-71
May 15, 2009 11:10 AM
greymustang
Jun 2, 2005 08:55 PM
