Head light dims?
Old Apr 22, 2008 | 11:27 PM
Bert's Avatar
Default Head light dims?
Well I tried the search but it wont work so i have a question. I noticed tonight while out cruisin around that when my brights are on and I'm at a stop if I give it gas then it brightens up and when i let off it dims down, is it supposed to do that? Sorry if its a dumb question but I never noticed it to do that on any of my other bikes. It only does it when the brights are on not the running one.
Old Apr 22, 2008 | 11:43 PM
RCR's Avatar
RCR
Default RE: Head light dims?
it does on my 929 even when the rpms go down (coming to a stop)they get dimmer on low beam even.
Old Apr 22, 2008 | 11:54 PM
Bert's Avatar
Mine doesnt on the low beams just the high. I was just wondering if i was losing some power or if my battery was bad. So it is normal then?
Old Apr 23, 2008 | 12:53 AM
vtrstunta's Avatar
it's normal.
when on hi beams, your headlight is using 165 watts (which is a lot, considering it's a bike)
if you roll around with hi beams all the time, it will eventually, slowly drain your battery, over the period of a few days or couple hundred miles (so either dont roll with hi beams 24/7, or hook up a battery tender every few days)
Old Apr 23, 2008 | 01:56 PM
gbcap's Avatar
yes your headlights run off the battery, but they are also tied to the stator. so the stator is spinning more at higher rpms.
serge1284
Jan 21, 2008 04:22 PM
djtrix92
Dec 12, 2007 04:54 AM
CBRF4
Jul 10, 2006 07:02 AM
burn8756
Jul 9, 2006 04:43 PM
koelzer18
Mar 30, 2006 06:16 AM
