Hard to start?
Old Feb 25, 2010 | 07:35 AM
railcrzy's Avatar
Default Hard to start?
If i let it sit for a couple of hours it has to crank a long time before it will start. It runs fine once started. If i turn it off for 5 or 10 minutes it starts right up. Could it be the fuel pump not keeping up the pressure?
Please hep. Larry
Old Feb 25, 2010 | 10:47 AM
bubba_finch07's Avatar
does it prime when you turn the switch? check the fuel presure regulator. Run some seafoam through your bike on a lowish tank. Just in case injectors are a little cloged up.
Old Feb 26, 2010 | 07:17 AM
railcrzy's Avatar
Not sure if it primes is there a way to tell without taking thing apart?
Old Feb 26, 2010 | 07:32 AM
when you turn switch to on position, you should hear it buzz. its pretty loud. hard to miss
Old Feb 27, 2010 | 10:59 AM
railcrzy's Avatar
The battery seam week and the fan comes on with the switch. This is in a sandrail. Im wondering if the fan is pulling too much juice from the battery and whatever is needed for priming is not getting enough power.
Old Feb 27, 2010 | 11:25 AM
skip954's Avatar
if the batt is weak or the fan running it would be hard to start put a switch on the the fan wire that lets you control when it runs from the seat. carge the batt for a night on a 1.5 amp charger. then start it see what happens, if you havent put the fan on a switch unplug it before trying to start..........are you useing the original fuel pump or aftermarket?
Old Feb 28, 2010 | 07:43 AM
railcrzy's Avatar
Ill try that thanks.
Im not sure if it is the original fuel pump i bought it built.
Old Mar 25, 2010 | 03:58 PM
yjk1975's Avatar
Charge up the battery. But my bike, the fan does not turn on when starting. Fan should turn on an off with the temp. The priming sound is more of a loud buzzing.
Freewax
F2 Tech
Mar 5, 2011 09:37 PM
oystein1988
Feb 14, 2010 10:44 AM
JayBoCC2
Jun 23, 2009 10:23 PM
motorbyte
Nov 23, 2007 11:32 AM
Flamed900RR
Apr 25, 2007 10:50 PM
