Exhaust header
Old Jun 27, 2017 | 10:57 AM
avisailflores1's Avatar
Originally Posted by Conrice
The red plug for the bike is the ignition rotor off the crank IIRC. Post a pic to be sure. I would try to put the PCIIIr into "zero" mode witch no modified map for the bike to run. Was there any map on it?
The PCIII did not have a map on it. I loaded a zero map and exact same problem happened. Loaded the map for the Micron and same thing. With the PCIII connected it turns over and its getting fuel but it seems as if the timing is off..If I connect it back to stock it fires rite up no problem at all. I'm going to assume that i just need to buy a new PC. Plus the PCIIIR is a P.I.T.A. to put a map on lolol I had to find a computer with a com port and then take it to the garage and all that jazz not fun at all...
marty2900
Jul 8, 2007 05:28 AM
makrr
Jun 6, 2007 06:15 PM
SpaceDocking
Mar 21, 2007 12:03 AM
