engine build?
Old Apr 16, 2012 | 08:42 PM
not_agn's Avatar
I'm not going to get into all the specifics. Its way too much to type. I built an engine. Wouldn't do it again. Rick at erion racing told me the honda cylinders are not plated from factory. Not to go larger then .25mm over. Anything more would have to be nikasill plated. Without the plating you cylinder walls will be to thin. He said the 2 best things for the 954 is high compression pistons, port/polish the head. Nothing more without spending lots. There is basically no aftermarket for the honda. I had 5lbs shaved off the crank. Titanium rods, 1mm over pistons. I was told the crank will flex to much and eat up bearings if you rode alot of miles. Not like a racer where you will tear it down and freshen it up. The bike was fun!!! rev'd fast and had plenty of power. I was at 160hp at the wheel. With a conservative break in tune. If I was to build a motor again it would be suzuki, or kawi. Huge aftermarket!! And cheaper. Any questions just ask.
deadsp0t
Jul 27, 2014 02:11 PM
Eighty2Fifty1
May 23, 2011 06:53 PM
rotaryhead
CBR Zone
Nov 11, 2010 10:38 PM
houseinateor
Feb 8, 2008 05:04 PM
toyotafj40s
Jan 21, 2008 07:01 PM
