f4i engine build...
Old Jan 20, 2008 | 10:54 PM
toyotafj40s's Avatar
Default f4i engine build...
So I found a '01 f4i engine for 50 bucks. my current engine is just fine..
timing was messed up from an improperly installed timing chain and some valves were bent..
A friend and I tore the engine down today and found this..
no idea where this is from. not from the pistons might be from the chain tensioner guide? found it in the crank case.
here's the bent valves.
the tranny, clutches, and block are all in good shape. so is the head.. basically we could throw in new bearings valves, and rings (y not while in there) and call it a day. but i think we're going to get a lil crazy with it
we were looking at boring the block out to 618cc and then installing a wiseco kit. then a port and polished head with a pcIII and custom tune.
any idea what this will amount? im thinkin this project should run under 1500 everything said and done. does this sound reasonable.
is the stock bottom end up to the task of higher compression/slightly bigger pistons?
here's the kit
http://www.wiseco.com/PDFs/Catalogs/...etOverbore.pdf
please let me know
thanks fellas..
Old Jan 20, 2008 | 11:27 PM
f4ez's Avatar
Default RE: f4i engine build...
im not very engine savy so really the only thing i can tell you is that marb menthol lightsare the best when you are drinkin
Old Jan 21, 2008 | 12:18 AM
haha thanks for that.
we havent cracked any open while messin with the engine yet. but we will..
just found out it's 30 bucks a pop i need to replace 8... the other 8 either exhaust or intake, i forget.. we will be keeping!
let alone the new bearings..rings..head gasket... etc..
yeah my buddy and i will be rebuilding this unit stock now haha!
Old Jan 21, 2008 | 02:05 AM
klutch_r's Avatar
The block will handle it no problem. JE and Wiseco pistons run a little over $500 online, complete with rings and pins. Con. rods are another $250. Gaskets are cheap; should be able to get them all for $50. I'd get some used valves...20-30 bucks?
Old Jan 21, 2008 | 09:54 AM
any idea where i can pickup used valves? I'll keep my eyes peeled. they are way expensive from honda!
will the stock connecting rods not be able to hold up to the higher compression?
thanks!
Old Jan 21, 2008 | 03:26 PM
Jaybird180's Avatar
Why not try and get another "parts" engine?
Old Jan 21, 2008 | 03:34 PM
hmmm. if i come across one for cheap like this then sure
Old Jan 21, 2008 | 04:15 PM
klutch_r's Avatar
You won't need the connecting rods, no...but if you find a deal on them, or as part of a package, it certainly wouldn't hurt. Valves might be a bit tricky to find, but take a look at people parting out bikes, especially on Stuntlife. Lots of blown F4i engines that people are taking apart and selling individual components; I'm sure you could get all the valves for less than $50.
Old Jan 21, 2008 | 07:01 PM
i found a head for a f4 shipped to my door for 80 or less depending upon the ebay auction.
the engines in the f4's were the same as the 01 f4i's from what i've been reading up on. well the heads and head gaskets at least
lol found a new head gasket (honda) on ebay for 6 bucks shipped too. **** buying new valves! just machine the old ones
also thanks for ur help man. i've been checkin out stunt life (im a member there) nothing has popped up for that so far tho.
also if you have any insight on where to find these big bore kits let me know
so far i've found a wiseco kit for $605. comes with the head gasket, pistons (no conn. rods) and something else ahha i forget.
deadsp0t
Jul 27, 2014 02:11 PM
skip954
Apr 16, 2012 08:42 PM
Eighty2Fifty1
May 23, 2011 06:53 PM
rotaryhead
CBR Zone
Nov 11, 2010 10:38 PM
houseinateor
Feb 8, 2008 05:04 PM
