Cylinders 1 and 4 filling with fuel
Old May 14, 2010 | 01:00 AM
TeamHondaOregon's Avatar
Default Cylinders 1 and 4 filling with fuel
Okay so I ordered a new fuel pump the other day, installed it, bike fired right up. ran it for a while just in the garage, tried to start it the next day, wouldnt turn over. pulled the air box and checked the cylinders to see 1 and 4 were completely full of gas. The injectors were shooting a steady stream of gas ONLY into 1 and 4, so I switched the injectors 1 and 4 with 2 and 3 and they still only fill 1 and 4. I then disconnected all 4 wire plugs going to injectors hoping it was a computer related issue, but still no change. Also the fuel pump relay just died, so another one is on order. Any ideas? Thanks
Old May 14, 2010 | 10:54 AM
bubba_finch07's Avatar
get a manual and test the injectors. they should be pulsing not a solid flow, my bet is they are bad. But if you don't already, get a 954rr manual and it will show you how to test them.
Old May 14, 2010 | 11:11 AM
Yes I agree, this is almost like a stream of **** lol.... I thought I did test them by switching 1 and 4 with 2 and 3 then back again to confirm? If it was the injectors that were bad wouldn't injector 1 and 4 be shooting streams and not just following the cylinders? Thanks
Old May 14, 2010 | 11:36 AM
computer may be bad then if it is JUST those injectors.
Old May 14, 2010 | 11:53 AM
I would agree it to be the computer, BUT we did pull the 4 wire plugs that went to each injector, there is no computer connected to them so you pretty much have to rule that out unless theres something I'm missing. Thanks
Old May 14, 2010 | 02:36 PM
your computer runs your efi, tells when the plugs to fire, injector to pules ect.
Old May 14, 2010 | 08:23 PM
Right. But with the wires pulled from the injectors, its still shooting gas to cylinders 1 and 4, regardless of which injector I use which makes me think that maybe it could be the fuel pressure regulator? I don't know just a thought. Also could there be some junk that washed into the bar that the injectors connect to? I haven't taken it apart yet, is it just a single tube that fuel flows through or is there lines inside it that go to each injector? Thanks
conzar
Apr 9, 2014 06:10 AM
craywm
F2 Tech
Jun 15, 2011 11:56 AM
paseo12
Oct 9, 2008 11:44 PM
RideHonda
Mar 3, 2008 11:03 AM
rookie600rr
Nov 28, 2005 10:16 PM
